- Oct 31, 2002
My First Attempt to............[Firestorm]
Well here it is, My Beauty, inspired by all the modcases i saw on the internet, and the fact that i wanted a watercooled system to and thought, "well i think i can make something nice to"
Since this is my first modcase i took all the time to do it as neat as I want it and finding the right materials, for the watercooling parts i went to XXLcase because of the good advice and service.
For all the Electronica parts and the lighting i went to a local store in my hometown where i was a regular customer for the last 4 weeks or so
The Spraypainting and the airbrushing is done by a friend of mine that does the painting for a living i could never got it that nice looking myself
After i started building, i encountered less problems then i thought there would be only the building of the Thermostat that switches between the blue and the yellow CCFl when the case gets over about 30C was the hardest part because i got lill experiance with electronics
Ok, inside the case is a Duron 1200 @ 1450 ATM but that will change in a couple of weeks to a AMD 2600+ with a radeon 9700 Pro
The baybus i made myself is from left to right :
top : yellow CCFL - 5 volt Fan front - off - off
bottom : bleu CCFL - 12 volt Fan front - Bleu EL on - Waterpump on
Beneath the baybus is a LIS LCD-Screen for reading, well just about anything ( http://www.bit-tech.net/review/119/ )
Well this was my case.
here all the light combinations
If you want to see more pictures from the beginning till it was done, visit http://members.home.nl/ruiter or http://www.gruntville.com/casegallery/My-first-mod-Case-:-Firestorm
near Future plans :
- x-tra 120mm enermax on back of the radiator for more airflow and lower rpms
- replacing fans 550 watts Q-Tec PSU by enermax 80x80 1500/2300
- drilling 1mm holes on the other side of the case in sghape Wu-Tang logo with yellow ccfl behind it
- a water graphic block for the radeon 9700
- a water chipset block for the mobo
- a 4x20 charaters lcd screen on the control unit of the LIS lcd
- a red CCFL for the water temp incl. a thermostat to turn the light on or off, tempature based
- home made ddr water blocks
- controller card to replace the baybus and do everything software maticly
near Future plans :
