With the Glaciator, my CPU is only a couple degrees C above the MB temperature at idle so I don't think lapping would make that much of a difference. Maybe at full load it would make a difference, where the difference is 10C or so.
these are very well made sinks I would expect them to have a pretty flat base to start with. Of course lapping with some higher grade may smoothen this out a little
... what kind of results are the rest of you having with this heatsink? I have read some of the info on how the onboard thermistor will give misleading results with the millenium, my reported temps. aren't any better than with my Alpha 6035. I haven't been able to increase the MHz on my AXIA with this sink either. ...Jury is still out on this one as far as I'm concerned.
Phil (Jun 20, 2001 08:15 p.m.):
sequoia464 (Jun 20, 2001 08:38 p.m.):
i'm only using the onboard thermistor and my temps are a few degrees C lower than my swiftech mc-370. i can run my chip at a higher speed w/o having to up the voltage to the max on my kk266r as i had to do with the swiftech... this is the best air cooling i've used... but i'm gonna go with water in a few days when i have all my parts...
