Haddy said:ok ive seen all u guys say u got urs for like 20 bucks...but cheapest i can find them for is like 60, i dont know much about freon and all that good stuff so i want to buy new......anybody help me find a cheaper one???
FireMogle said:I heard somewhere that the small cooler type fridges actually have a pelt in them, just wondering if anyone else has heard this? If so a wattage from one? Just wondering if it would be a cheaper way to get high watt pelts.
JoeCrappa said:is there any non-permanent way to insulate your motherboard for condensation?
There are lacquer sprays available from many electronic stores which are clear. I don't know brand names.JoeCrappa said:is there any non-permanent way to insulate your motherboard for condensation?
It's really quite simple. The fridge has a metal box (evaporator) at the top usually with a plastic door on it. If doesn't have that then it is not a freezer type.Haddy said:lets go with the lowest temps possible.....can somebody maybe show me a link to one of these freezers so i can know sorta what to look for......
