- Mar 12, 2002
So while I do know its always preferable to have matched kits I have a unique situation.
So I am decommissioning old systems from my studio, and have a couple of older dell mini pcs I no longer need or want, and do not boot.
So rather than wasting time or money I decided to tear them down to their usable components.
And I have now a few extra sticks of memory that are compatible with some systems I am keeping going.
I have 2 ZBook G3s with 16Gb RAM currently.
Anyway with the extra RAM it will be possible to further upgrade the systems but its going to be mismatched. Now I figure since I am using stock timings this should be ok.
Original ram is DDR4-2133 CL15 8GB Samsung sticks. What I puled are a couple of DDR4-2666 CL 16 Micron multiple size sticks, all sticks rated for 1.2V.
According to the documentation it should operate at the slower sticks speed which is what I want, and to that end I assume the 2666 should be able to handle the slightly tighter timings of the 2133 memory.
For one I am thinking about doing 16 + 2x 8GB for one unit configured with 8Gb sticks in slot 1 and 3 and the 16Gb stick in slot 2 this should even out the loading on the memory controller ish??
Then the other unit I think I will just drop my 2x 4Gb sticks in and upgrade that one to 24Gb total. These are all matched 2133 CL15s so I forse no issue putting 1/3 and 2/4 in an 8Gb + 4Gb configuration.
Thoughts advise?
Thoughts advise?
