Anyone have any thoughts about this idea:
I was thinking about those misting fans that you always see on the sidelines of NFL games, and how something similar might be used in water cooling. Of course these work on the same principal as bong cooling, but how about this variation--use a traditional radiator/fan arrangement (outside the case) but place a misting sprayer between the fan and radiator, spraying on the rad. In other words, you'd have the fan an inch or so behind the radiator with ducting sealing the rad/fan unit, and a small mist head in between. I'd think that mist evaporating off of the radiator would provide some extra cooling. My thought is that you'd have a separate reservoir/pump for the mist unit so that--unlike a bong, you'd still have good cooling even if the mist reservoir ran dry. You could use the mist sort of like a 7-12v fan switch--cut it on when you are doing high-load activities. Instead of using higher fan speeds and creating more noise, you'd just use up a little water and create some humidity.
I might have to try this out when I get in my new stuff next week.
