- Mar 22, 2002
OK, I don't get it. What is the difference between a regular XP and a mobile XP. Their both socket A right? They run at all the same speeds (now up to 2200+). So the only difference I THINK I can find is that the mobiles use less wattage. But then, why don't they use them in regular setups? I always thought mobile processors (amd or intel) used different sockets to squeeze into those laptop mobo's...
so confused... enlighten me!
thanks
thanks
