- May 29, 2003
- Ontario, Canada
if you're running blend then it's not really testing your cpu stability. you could try dropping your northbridge voltage to 1.6. you should not need 1.7 for 200fsb. i run into stability issues if i put my nb voltage at 1.7 on my nf7 when at 200fsb.
if you want to test just your cpu stability then use the small ffts test.
