- Jun 16, 2004
- Berkeley, CA
mmmm there are a lot of options...it's difficult to say...check out my SI-97 thread. There's a lot of info there, including my setup.
gsan_bot said:for mobile barton 2400+
IQYHA 0401 MPM
FJQ4C AQYHA 0409SPMW
which one is better? pls reply hurry, i gotta buy it asap! thanks!
gsan_bot said:how about thrmaltake silent tower heat pipe?
does it fix with abit nf7 v2.0 ?
good luck! no one knows.gsan_bot said:hmm... which one the FSB can go higher?
gsan_bot said:off topic.
i wonder why you guys here just oc to get the highest speed
but not the greatest performance huh?
If you're referring to the above, no one will be able to tell you how your chip will do. Welcome to the world of overclocking. It's not all about the steppings. You just have to see how lucky you are.red_dragon said:good luck! no one knows.
