- Oct 27, 2004
Ok gang. I haven't upgraded my motherboard/cpu since the abit IC7G was brand new and the 2.4Ghz p4 was top of the line.
The system has finally been brought to it's knees by Oblivion and being a HUGE morrowind freak, I simply can't live with the game knowing that I'm only seeing half the goodness. The 6800GT helps some but still shows weakness and it's time for an overhaul.
I only need a new mobo/cpu/gpu. I'm wondering if there's anything new and fancy just over the horizion that I should hold off on this purchase or not?
If not, then I need a good 939 board, good GPU and not necesarrily the most expensive/fastest AMD but one that offers the best bang for the buck. I'm assuming there's a popular dual core model that overclocks well?
I'd like to be able to overclock the system too (that's why I'm here right) so stability plays a role. I know I want SLI and I'm figuring that if I get a decent SLI board and something like a 7800 or 7900 nvidia, It would be ok and if needed, just slap another one in there next year or something?
I don't really need a whole lot of bells and whistles on my motherboard. Just the basics: SLI, stability, audio not required, usb and speed. I'm also using a zalman 120mm heatsink so the CPU socket needs to not be on the edge of the board. Centralized location would be ideal but from what I've seen, most sli boards have that. So no $180 motherboards with hd audio or integrated cooling or any of that stuff is needed so I'm hoping I can save some money in this area. If not, though, that's fine.
So bring on the help and suggestions. I've been out of the tech loop for a while so I'm all ears.
I'd like to hopefully try and keep the budget around $1000. It's not set in stone or anything but that's what I'd be most comfortable spending if I know I'm going to get as much use out of the core components as I've gotten out of what I'm using now (Since December of 2003!)
Just a current guess as to what would be decent would be
- DFI NF4 Ultra D motherboard
- BFG 7900GTX
- AMD Opteron 170 Denmark
Totalling just over a thousand. I could work with that. Is that AMD decent though? Or is there a better bang for the buck overclocker out there for $400 or less?
- BFG 7900GTX
