Here is the general idea
What you are going to need to do is....
Find out the Voltage of that CAP ( probly 6.3V)
And find the capacitance, µF, (probly 1000µF -1500µF)
Once you have this info if can buy a new CAP, it will cost under $.50.
But since we are overclockers…. We might as well replace the cap with once that has a little more punch. So when you goto buy a new CAP, you may want to get one rated for a higher voltage…..
This is the tricky part.
Soldering Iron (fine tip), Solder and a Fine Point Scraper are req. Solder sucker if you have one is nice… but not req.
Step 1: Removing the OLD CAP
Remove MB from case, and everything attached (RAM ect)
On the back of your motherboard, were the leads from the CAP stick out, you will need to touch the HOT Soldering Iron on them so the Solder melts and you can remove the cap… The cap may not fall off so a small tug may be req.
Step 2: Inserting the NEW CAP
Insert the new CAP leads into the two holes (may have to sand the leads a little to make them fit) from when you removed the OLD CAP….
ENSURE that you put the CAP in the correct way, Positive to Positive. (the longer lead on the CAP is Positive, and the board should be marked for what hole is positive)
And be sure that the CAP is not blocking anything on the front side of the MB, and this holds even more true if you get a LARGER CAP.
Step 3: Soldering the new cap
On the back of the motherboard, you are going to solder the two leads from the cap to the motherboard. Don’t apply too much heat to the new CAP. Heat can kill it, so make you connections quickly…. A small heatsink on the CAP may also be a good idea. You need little Solder, and once the NEW CAP is Soldered into place, ensure that no extra solder is touching anything that it shouldn’t be touching. Use the Scraper to clean around your solder job, double checking you didn’t connect anything else by mistake. Then Cut off the extra length from the caps (as they will stick out about 5cm before you cut them.
And with any luck, your done, and have a working board again.
Saved a Abit BF6 like this, I Blew 3 CAPS ,6.3V, 1500 µF
And replaced then with 3, 25V, 1500 µF CAPS
