This is what microsoft says about Code 12
"Code 12
This device cannot find enough free resources that it can use. If you want to use this device, you will need to disable one of the other devices on this system. (Code 12)
Cause
This error can occur if two devices that are installed on your computer have been assigned the same I/O ports, the same interrupt, or the same Direct Memory Access channel (either by the BIOS, the operating system, or both). This error message can also appear if the BIOS did not allocate enough resources to the device.
Recommended resolution
You can use the Troubleshooting Wizard in Device Manager to determine where the conflict is, and then disable the conflicting device.
Disable the conflicting device
On the device Properties dialog box, click the General tab.
Click Troubleshoot to start the Troubleshooting Wizard. The wizard asks you some simple questions and provides a solution to your problem based on the answers that you provide.
Follow the resolution steps provided by the wizard to resolve the problem."
I don't know what USB device is not getting enough resources. Also everything is working correctly
Any ideas guys?
