mobo settings
onimo
what are the default CPU Core: Bus frequency [DSFID switches] settings for the duron 900?,
and also what is the default Voltage Regulator [VID] settings?
will my GORB be enough to keep my CPU cool enough till i get so better cooling
onimo (Jul 04, 2001 08:06 a.m.):
welcome to the forums
if the chip isnt unlocked then the motherboard settings dont matter but the default voltage 1.75 and the default multiplier would be 9x100.,about the orb I dont really know but I dont believe you would be able to do any overclocking or even default settings with the orb but you may just have to try and see but if you do just keep an eye on your temps .
wildone
thx for the help
and i now i wont be able to do any overclocking just yet but just wait till i get a better hsf
