Mobo under $70
Jacobman
redding, California
I am looking for a mobo under $70, i have a PCI-E x800pro to go in it. I was looking at the ASrock sata2 based on what you guys have said about it. Is that the best bang for the buck?
It is certainly very good for under $70, but it has problems over 274fsb, and VCore/Vdimm options are very limited. You can get a good OC out of it, with the right CPU (probably a 3200+/146 Opty or better), and good components. To really push the OC you will probably need to do the voltage mod.
The other decent choice under 70 is the Chaintech VNF4, but I don't know much about that one:
http://www.newegg.com/Product/Product.asp?Item=N82E16813152053
