- Mar 29, 2003
I modified another hard drive. This one was much easier than the first. The original cover used a piece of Aluminum(Aluminium) tape to seal the cover. I used the same material - Aluminum Duct Tape cut into thin strips, I used 2 pieces because of the large gap. In the picture it looks white because of the paper towel. In the dirve is a WD Caviar 2700 same construction as the WD 2635 in the picture. I have done a low level format and installed an OS on the drive......
