- Dec 13, 2005
Sorry for the confusing title -
I currently have two 27" monitors. One is 1440p, the other is 4K. My problem is how Windows 10 handles pointer movement and window size.
I have them both on a mount so both are set at the same height, and in the Display Settings menu I have them set accordingly. But, as they are different resolutions, Windows sees them as different "sizes", so when moving the pointer from the 4K monitor to the 1440p monitor, it'll sometimes get hung up on what it sees as the top and bottom of the 1440p screen.
Is there any internal setting I can play with to get it so pointer movement is seamless between the two?
