modules.dep got deleted
Christoph
JAPH Senior
Redmond, WA
I just found out the hard way that my computer isn't entirely stable. After its most recent freeze, I rebooted and got several errors during the boot up. The things didn't quite work correctly (no internet access or sound) so I rebooted and started in failsafe mode. While I was booting up in failsafe mode, I noticed that most of the errors had something to do with modules.dep not being found.
Can I rebuild modules.dep?
Christoph
Christoph
JAPH Senior
Redmond, WA
Depmod won't do anything without modules.dep, and I didn't see any options to rebuild modules.dep. Sorry I'm such a newbie at this.
Christoph
Christoph
JAPH Senior
Redmond, WA
mcrites said:
Did it make an empty file or just do nothing? Are you running it as root?
It didn't make an empty file. I was running as root (I couldn't access it otherwise).
I'll probably just try it with an empty file.
PolyPill
Senior Member
Germany
Well you can always reinstall your kernel and modules, either through the original rpm or if you compiled it just do a make modules_install
Christoph
Christoph
JAPH Senior
Redmond, WA
How do I tell which modules I need to reinstall, and what are the files I need to install them? I have mandrake 8.1, so when I installed I just let the installation take care of itself (no compiling, manually installing RPMs, etc).
Also, is what you mentioned the simplest way to get my system back online? I need to have it online by Wed. to turn in my computer science 210 homework.
Thanks for your patience mcrites and PolyPill.
Christoph
Christoph
JAPH Senior
Redmond, WA
That isn't working. Looks like it's too fubar for my humble skill. I'll just reinstall and make sure to read up on Linux more often. I'd much prefer to fix the existing installation, but I've got a programming assignment due in 2 days, and I need both days to do it. I realy appreciate your help, and even though I didn't fix the problem, I did learn a thing or two about Linux.
Christoph
Christoph
JAPH Senior
Redmond, WA
Well, Mandrake is all reinstalled, but thanks to mcrites' instructions, I had no trouble mounting the partition that had all my old data on it!!! Looks like I've got a fresh install with all my old data intact. Great job!
