Should allow you to do hybrid crossfire graphics with the 6670 and give you better performance than the 6670 alone. That being said a discrete graphics card of a higher quality will always be better.
My sons are getting an operating system somewhere else.
Thanks to all of you. This has all been great advice and we will make the final decision based on cost and function tonight. I am trying not to rush but they are anxious to order. I'm sure we will order a better graphics card based on this advice. I don't want them to spend all their money and not have it work the way they expect. I will reread all of your posts before finalizing the order.
Thank you all so much! This is a incredibly friendly and helpful forum.
You can't use a 7770 in AMD Dual Graphics with a APU. The highest card you can get and use this feature is a 6670. We are estimating that a 6670 in dual graphics mode with an APU should give similar performance to a 7770.
