Monitor does not wake up
data1
Hi
I have recently have this problem that when I start the PC the monitor enters to power saving mode and does not wake up from there (black screen all the time)
The windows starts normally (can hear from sound).
I need to turn off the PC quite many times until it finally is able to turn the monitor on.
has anyone else got this same problem?
what should I try?
The PC specs are in sign below.
thx
The monitor is:
DELL 24" ULTRASHARP U2412M IPS LED
ATMINSIDE
Does this occur with a different computer connected to the monitor?
Leegit
Kansas
You need to hard reset your monitor. e.g. unplug the monitor from the power source for a few mins then plug it back in. :thup:
ATMINSIDE
unfortunately i dont have another PC to test this except my laptop but that doesnt have right plugin (it has VGA).
Grab a $5 converter to go from VGA to whatever else you need.
D
data1
Well it started again today and having power off the monitor for couple of minutes did not seem to help. i just had to reboot several times to get it on.
ATMINSIDE
My suggestion is still to connect your other computer to the monitor to rule out the computer as the issue.
