- May 3, 2014
Hi, so I've been getting this problem lately and i wanted to make sure it was fixed and wasn't causing any real damage to my system.
When i start my PC in the morning, My monitor light doesn't turn green but stays orange/yellow thus not recognizing the PC is on or connected?
I have to restart a couple of times manually via the power button until it eventually does recognize and the monitor light is green and it starts working.
Also I've noticed instead of holding the power button for it to restart, i simply press it once and it instantly turns off the PC, and then i proceed to put it back on and repeat this a couple of times until the monitor turns green and connects.
One more thing i'd appreciate help on is that whenever i start my PC, after I've gotten the monitor to recognize the PC, aka the green light on monitor is on, i get the 'CPU fan error' which i then press f2/del and go into BIOS, where i then boot into windows. The Fan error always occurs no matter what every morning when i put my PC on. I remember quite some time ago having this fan issue and fixing it but it came back, and i'm more concerned about the other issue.
I'm not sure if Dust has anything to do with it but my air duster(s) should be arriving any day now and i will thoroughly clean inside of my PC, maybe that will fix some issues, just looking for some clarification on these problems.
Any help is appreciated, Thanks.
