- Thread Starter
- #41
... snip ... From there, we can indirectly control the amount of heat dissipated into the air by having better thermal transfer into the block (aka, a better mount). This does, however, mean that more total heatload from the cpu will enter the block, and if you follow the chain, more will enter the water. This is theoretical, I cannot say if it will work exactly like this irl, but in terms of theory, better mount = more energy dissipated into the water, which means higher water temperatures, and the increase in rad performance at that higher temp means that the water's equilibrium will only increase slightly. This warmer water is not reflected in cpu temps and actually will be reflected in LOWER cpu temps because the cpu is able to disperse more heat into the water.
Hmmm, who is right here probably doesn't really matter, but the discussion is interesting, so I will continue.
Will water temps increase if the block is mounted better? I continue to think they won't - at least not measurably. I will state, for the record, that you are undoubtedly correct about the water temp changing somewhat - I just don't think you will be able to measure it with the instruments we have available to us in the water-cooling world, most of which seem to work to an accuracy of about 0.5C.
I do agree with most of what you have said, but I think our two arguments rest on the delta between how much heat is transferred into the air/mobo/etc rather than into the water (via the block) for a poorly-mounted vs a well-mounted block. i.e. When the thermal path to the block/water is more resistant, is there significantly more heat transferred to places other than the water?
For you to be correct, the answer would have to be that yes, significant additional heat is radiated elsewhere, if the thermal path to the block is poor. For me to be correct, the difference in heat radiated elsewhere would have to be minimal. the answer, of course, comes down to how much more resistant the path to the water has become.
I think we can agree that conservation of energy dictates that the total amount of heat radiated will equal the total amount of heat produced by the chip. We know it's going somewhere, or the chip would shutdown/fry.
It just comes down to whether it goes via the water, or via the mobo/air.
What I reckon is happening, is that the chip can't dissipate heat to the air quickly enough to stop it from frying, so it heats up until it has enough of a temperature delta to overcome the increased thermal resistance of the path through the block.
With a poorly mounted block, let's say we see a cwdT increase of 15C over a well-mounted block. That means that the chip will be an additional 15C hotter than the surrounding air. Can 15C more make a significant difference to the amount of heat transferred to the air? This probably represents about a 50% increase in the chip/air delta, giving us a corresponding 50% increase in the amount of heat transferred via the air. (I think the relationship is roughly linear.)
So, we started (with a good mount) with Hw watts of heat going via the water and Ha watts of heat travelling via the air. We now have Ha * 1.5 travelling through the air and Hw - Ha*0.5 travelling through the water.
Let's say, for argument's sake that Ha is 1/24th of the amount travelling through the water. That is the difference between the thermal conductivity of water vs. air and assumes that the surface area of the water interface is the same as that of the air interface. (Which is strongly skewed in favour of the air interface - it won't really be anywhere near that much transferred to the air.)
Running with these figures, we start with 4.2% of our heat going via the air, for a well mounted block. Once we have cultivated a little algae, we end up with 6.3% via air. That (extremely generous) 2.1% of our heat that was diverted represents about 4.2W. (Assuming your CPU is chomping through 200W of power, which it might be, overclocked.)
The heat capacity of water is 4.179 at 30C. 4.2W = 15.12KJ/h. 15.12KJ will increase the temperature of 500ml of water by 7.23C. So, if we have 500ml of water in our loop, that 4.2W (if not dissipated by our rad at all) will increase our loop temp by 7.23C, over the course of an hour.
However, the story does not stop there. Looking at the skinnee labs review of the smallest radiator I can find on their site, we see that an increase in awdT of even 1C will increase the amount of heat radiated by about 15W, so 4.2W will cause an awdT increase of about 0.28C, as the rest will be radiated.
So, if we expect the thermal interface to the air to have the same area as that to the block, and if we manage a 15C improvement in block mounting, we just might see the water temps notch up past a half-degree increment.
Not sure if I made all of that entirely clear, but it seems that (in this extreme example) you might just be able to measure the difference in water temps, if you have a very accurate sensor, but probably not.
