- Dec 29, 2000
Probably not too high because they are trying to shrink everything to speed it up. At least I think that is why the die (core) shrinks make for faster chips. Something to do with a shorter path. But I'm not very knowledgeable in that area.Wonder what the plausibility of making a larger core on the same architecture is...basically increase the surface area so that you can cool more efficiently...
What I'd like to see is an integrated top that is made of copper and thick enough to act as a good heat spreader. I wonder if it would be possible to remove the standard one and solder a new one on? But probably easier to just buy higher end water or even a phase change system.
