- Jan 19, 2008
- Folding the PWN, Salem Oregon
A tutorial
1. Download Hamachi for free here, you'll want the un-managed version. Install like any other program. I recomend installing on your main pc that you will monitoring from first.
2. Click the power button in the top left corner, you'll be asked to create a name for this computer, the default should be fine but can be changed to make it easier to identify which computer it is.
3. Click "Create a new network" and fill our the name and password desired, mine is "DB Folding" and if i wanted anyone else to be able to log in to my network i could give them my password.
4. Should look somewhat like this except without others listed.
5. Install on your other boxes and join the network you created.
6. Turn on folder sharing and share the folders on the remote boxes. (C:\FAH, app-data\folding, etc...)
7. On your main computer you will be monitoring from start up HFM and add the client.
The top 3 are monitored over hamachi
