- Jan 31, 2024
- Gulf Breeze, FL
Threw this one together this evening for a 24/7 daily driver. I've used this combo before and knew exactly what to expect, but was surprised at how quiet it is vs the first one despite having more and larger fans installed. Two 140mm fans up top for exhaust and four 120mm fans serving as intakes. All spinning at low rpm and the psu's fan is dialed low as well. I removed the silly strap after taking the photos. 8700G cpu with the Noctua NH-P1 cooler. Zero lights or RGB.
Even with no fans on the cooler it does very well under load and recovers quickly. Cinebench23 with default bios settings...
Negative 30 on all cores PBO proved to be no problem at all. This pc will never see such loads in daily use.
