- Jul 14, 2001
- Tombstone,Conn.
I an running a A161 mobo with a AMD T-Bird Slot A.I can across an idea.I cut the rear of the plastic case right around the AMD sticker on the processor. Then I will mount a small heatsink fan over the opening to suck air out or away from the rear of the processor.The front of the bird has a twin fan heat sinf already.Theory both fans sucking on eigher end of the bird will case a small vacumm on the chip itself and cool from th rear and front. fedback anyone?
