- Aug 29, 2002
- Wash., USA, Earth, Milky Way
I need to add more cooling to my case. I dont want to go over 50db if i can help it with the fans. Here is what I have right now;
Front: 2 80mm 50cfm (Intake)
Back: 1 80mm 50cfm (Outtake)
Top: 1 80mm 50cfm (Outtake)
Here is what I am thinking about doing;
Front: Staying the same
Back: Adding another 80mm (Outtake)
Top: Adding a 120mm 126cfm (Intake)
Side: Upgrading to a 120mm 126cfm (Outtake)
Do you think this will work? Or is there something that I should change?
Thanks,
~Will
Thanks,
~Will
