More Glaciator data
earthdick
"The Garden State" NJ
Previously using the Coolermaster DP5-GH51 and running the KK266 with a T'bird 800. It was at 31 degrees idle and 48 degrees full load at 6 x 133 @ 798,1.725 volts in bios which gives me 1.79 volts, according to MBM 5. If I increased the fsb any further the full load temps would go well over 50 degrees. With the Glaciator the idle temps are 29 degrees, and full load at 36 degrees. I just upped the fsb to 7 x 133 @ 931 and it is running 30 degrees idle and 39 degrees full load and I haven't changed the voltage. It was very easy to clip on without using a screwdriver, but it is one heavy sucker. So far I am very happy with it. It is not much louder than the Coolermaster, which I thought was very quiet. I want to see how much higher I can go with the T'bird.
those are some great numbers. I think without a doubt, this cooler should be the one everyone buys for a new Tbird or Duron system.
