most used format for DVD
new_novice
san jose, CA
Well, I'm about to buy some media to burn my home made DVD, but was wondering what is the format that most DVD player read? Don't want to mess it up of course.
Thanks
cornbread
The great USA!
Copied and pasted from videohelp.com.....
Me personally I have better luck with the dvd-r, but my dvd writer writes both +-
_____________________________________________________________________
There are three competing DVD Recording standards, DVD-R/W and DVD+R/W have pretty similiar features and are compatible with many standalone DVD Players and most DVD-ROMs while DVD-RAM has less DVD Player and DVD-ROM compatibility but better recording features.
DVD-R and DVD-RW
DVD-R/W was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 93% of all DVD Players and most DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 79% of all DVD Players and most DVD-ROMs.
DVD-R/W supports single side 4.37 computer GB* DVDs(called DVD-5) and double sided 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R/W has some "better" features than DVD-R/W such as lossless linking and both CAV and CLV writing.
DVD+R is a non-rewritable format and it is compatible with about 88% of all DVD Players and most DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 79% of all DVD Players and most DVD-ROMs.
DVD+R/W supports single side 4.37 computer GB* DVDs(called DVD-5) and double side 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance.
DVD+R DL
DVD+R DL or called DVD+R9 is a Dual Layer writeable DVD+R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18).
DVD-RAM
DVD-RAM has the best recording features but it is not compatible with most DVD-ROM drives and DVD-Video players. Think more of it as a removable hard disk. DVD-RAM is usually used in some DVD Recorders.
This format is supported by DVDForum.
