mother board modifcation kt7 raid
kat
Senior Member
belding,MI,United States
just finished the modifacation about two hours ago managed to boost my core volts to 2.01 up from 1.92 im still not able to get the clock any higher but I was able to boot up and load windows at 11.5 multiplier , dropped the FSB to 100 from112 if I've done my home work right this FSB setting is safer for my peripherals?? has any one else done this to kt7 with any luck?
Hey kat
If you were stable at your 112 fsb then it shouldnt hurt your components.
The 112 fsb will give you better results than the 100fsb will give you. So if it is stable at 112 then i would go ahead and run it at that.
Cullen
cullen
cant run FSB that high at 11.5 only at 11.0 with the voltage increase i gained on the multipler but lost on the FSB and clock... best i can get now is 1165 wounder if better memory i bought will help should arive in the mail friday or saterday
