Motherboard advice
Wonko_The_Sane
PA
Hi
I'm new to the fourms and I might be buying a new motherboard soon. I was wondering what you reccomended.
Thanks,
ed
13rian
Hey sup!
everyone in here is gunna say sooner or later but i'll just do it for them, "it depends on what u want." [RAM, Processor, etc, etc....]
i'm getting an epox 8k3a+ tho, cuz it's generally stable, o/c-able, and up-to-date features for newer systems.
Arkaine23
Captain Random Senior Evil
motherboards
Welcome to the forums! I've seen your screen name b4 somewhere....
Hold out for the KT400 chipset if you can... and AGP 8x
KT333 boards: Epox 8K3A, Shuttle AK35GT-R r2.2, Soltek 75DVR
KT266a boards: Epox 8KHA+, Abit KR7a, Shuttle AK35GT-R or AK31a
What might you be willing to spend? And what features aside from OC'ing are you looking for? Onboard 6 channel sound? Onboard Raid? 3 or 4 dimm's? 5 or 6 PCI slots? Looks?
DKC
When will KT400 come out, and isn't the difference in performance supposed to be fairly minimal
W
Wonko_The_Sane
PA
what im looking for
on my name --I use this name in half life and it's taken from HHGTG
Looking for a motherboard that works with xp 1600+ and pc2700 if it had good on board sound that'd be a plus. right now i dont use much of anything pci so alot of pci slots isnt important.
ed
W
Wonko_The_Sane
PA
right now raid wouldnt be that important since i only have one hard drive but it's on my "things that i would like to use list"
as far as cost goes i think i should be ok if it's under 200
looks would be a plus but not too important
anything else?
Arctic
Ontario, Canada
you want good onboard sounds.. I would recommend the Shuttle Ak35GTR... it has 5.1 sound supports...its also got raid so that's a bonus if you plan on using it later on
