MBM 5.05 can be obtained from the author's website here:
What gets me, there is NO link to the additional dll and ini files that are needed for the newer chipsets. And the link where I found it at OC.com is now gone. So I'll stick the zip file on my webspace. Download the beta ALI files here:
Unzip and read the instructions for how to install the add-on for the ALI chipset (you need to install MBM5 first, then add the new dll).
This thread has a description on how to set up MBM to shutdown automatically at a temp you choose WITHOUT using the secondary program "Shutdown Now!"
If you're set on using the Iwill Monitor program, this thread has a link to the updated version so you don't have to email them.
The CPU temp seems to work fine for both, but I think there's something wierd going on with the system temp thermistor or MBM - mine is reported at about 33C, when I have a senfu temp probe sitting inside the case right next to the system thermistor that tells me it's 25C.
