Motherboard swap went OK except for network connection
Yomama
Senior Member
The battle born State
I could really use some help here.
Over the weekend I swaped out the motherboard and some components in one of my systems. I changed the motherboard, video card and (onboard) soundcard. With the MoBo I went from an ABit BX6r2 with PIII600@800 to an IWill KK266 with TBird 1.4/266 (actually 1/[email protected]/266). So the PCI bus should be at 33MHz - I am just stating this because that should really not be an issue in what I am about to describe...
EVERYTHING went really fine, of course a couple of drivers had to be re-installed but after a few re-boots everything worked fine, and the system is stable at 1.4GHz/[email protected].
EVERYTHING??? Well not exactly. Somehow I lost the TCP/IP layer of my network connection. I have a DSL connnection into a Netgear 314 Gateway router, connecting to a Netgear NIC. I have link-level conncectivity (actually TBase100), but for some reason I cannot connect to the internet or e-mail. I spent a total of more than 6 hours over the weekend to figure this out, but to no extent really. I swapped NICs (also have an Linksys card), uninstalled and re-installed drivers and even re-installed WINME. I am using IE5 or Netscape, and Outlook, and I just can't get out. Netscape tells me that it "...cannot establish a TCP/IP socket connection..."
I cannot do a fresh install, which would be my preference, but I have no idea how to recify this issue.
Any help is appreciated.
Yo
P.s.: Also posted this in the networking section, but there is only limited traffic there - sorry if this causes an inconvenience to anyone
I assume you've tried to reinstall tcp/ip under network preferences? right?
that's the only thing I can think of off the top of my head.
If that's not it I'm not sure what it could be....
good luck
Have you tried unplugging the modem from the PSU? Then plug it back in, sometimes this helps me out when I get those kinds of problems. It makes the modem reset and maybe this might help your case too.
Tacoman667 (Jun 25, 2001 09:25 p.m.):
Thanks for the replies so far. I have re-installed the tcp/ip for the network card and I even moved the network card to another slot and also replaced the network card with another one. I am still stupefied. I may have to bite the bullet and perform a fresh install - dang I wanted to avoid that.
Yo
here is probably what you need to do ,first off if you reinstalled windows you can use the internet wizard and tell it to connect through a lan , if you have already done this then goto start>run>then type winipcfg and hit enter , then click realease all then hit renew all , this should have you back up and connected
wildone
wildone (Jun 26, 2001 03:19 p.m.):
wildone
winipcfg did not work out either - man this must be screwed up - never been dead this long b4.
