So long story short I bought the gigabyte z370p d3 just before the z390s and intel 9th gen came out. I didn't realize how important the quality of the motherboard is to overclocking and I wanted to use a mix of Corsair and gigabyte to build my PC. So I of course went with the cheapest z370 board that would let me OC and met my aesthetic. I have a pretty good OC of 4.7ghz @1.2v. Sure the VRM gets a little warm but not too crazy. I now find my self in a situation where I can get my hands on a z390 pro wifi for basically free. The features on the board such as an extra m.2 slot, and onboard bluetooth connection and better VRM are what I am interested in.
My questions are this:
1) Will I have to start all over with the OC as if I never OC'd it before, meaning stress test raise it slow stress test again etc. Or can I use the exact same settings I am at right now as a base and possibly go higher, but worst case keep the exact speed and voltage I am at now.
2) I am going to put 2 m.2 pcie drives on that board and put them into raid 0. Yes, I understand about the risks and backing up and I also understand I will have fewer sata ports which will not be an issue as I will now act like sata is dead tech, but is this even possible without a performance loss. I don't care about performance gain, only performance loss. Ideally the only thing I want here is that the two m.2 drives will be merged into one drive and I will of course be booting windows from that.
Once again, the only thing I care about is if the above two things can be done without a loss in performance. I don't care about the cost, and I will be having my step son do the labor work. I know some people will suggest using usb adapters, or pcie cards and tell me not to even worry about changing the board, but unless there is a performance loss I prefer using onboard over expansion cards and usb. If anybody cares I am also getting the RTX 2080 to go along with this and holly cow good luck finding that for under a $1000 before tax in my country. If relevant the following is the build I am using right now:
https://pcpartpicker.com/user/robmartin703/saved/#view=cTWkdC
thanks in advance.
Smokey
thanks in advance.
Smokey
