MotherboardMoniter 5 Question
customrig
Wethersfield, CT
I would like to moniter my cpu temp. Which board sensor should i select to get that temp:
Winbond 1
Winbond 1 P2 Diode
Winbond 2
Winbond 2 P2 Diode
DarkArctic
Ontario, Canada
I think that it's one of the Winbond2. Look at Motherboard Monitor's site and scroll down the left side of your screen till you reach your motherboard manufacturer (Shuttle). It doesn't show your exact mobo, but I picked the closest one.
http://mbm.livewiredev.com/
-DarkArctic
Iron Hawk
Groton, CT
Try 'em all, usualy only two will give you realistic answers, one will be case temp the other (usualy the higher of the two) will be CPU temp.
