motherboards
joey_rjm5
What would be the best motherboard if i wanted to run an oc'ed p3 700 and i wanted a agp graphics card. I am not looking for anything sketchy, I just wan't somethin stable that can get me above 900 mhz. Thanks
Take a look at Asus and Abit boards. Both of these makers offer BX, via and 810 boards suited to your needs. Rather than seeking directly, try reading through the posts and see what's working for others. Good luck!
I am in the process of building another computer and will be getting a PIII 800. The Asus CUSL-C was suggested, and I think thats what I am going for.
Cyan
Just look at my sig...I use an Abit SH6 815e slot one, and so far, it's stable up to 158fsb...with good ram of coursecheck it out...in my opinionthe slot 1 815e is the most viable solution,naitive agp 1/2, ata100 suport, and with slot one you have the best of both worlds..with a sloket, you can use the 370 chips, but I don't think they make a slot 1 to 370 converter..or ever will.
I could never get this speed with a bx board
Hey doc do you know if there is a jumper for the i/o voltage on this board or not I've been looking for it. Thanks.
If your reffering to the SH6, then I don't know, I know it ain't in softmenu...what a shame...one of the few drawbacks..I could probably get a little more out of this rig with a little i/o tweeking...if you find one, lemme know
Check your manual for IO voltage settings. I have a CUSL2-C, when I wanted to up my IO from 3.3 to 3.6V, I had to move a jumper on the board.
