Mounting heatercore at top of case
jlin453
Austin, Texas
Thinking of getting a Lian Li case but it looks too cramped for watercooling. I searched the threads already of how people with the PC6's mounted their heatercores at the top of the case.
I might get this since I don't have a shroud handy:
http://www.cooltechnica.com/Merchan...&Product_Code=Coolshroud&Category_Code=Shroud
Should I still mount the heatercore,shroud, and fan through the holes of the fan? What size should I use?
Just wanted to make sure first before I did it. I don't want to buy a $100 case and then screw up on cutting the holes.
Lothar5150
Coolsleeves™ Guy
Surf City
Hi jlin453 with that shroud you can use the holes in the coreners to monut the core/fan/shroud assmebly to the case. The corener holes are a #4 (4-40 machine screw). For that type of mounting you might want to pick up some nice nylon spacers to cover the screws. That would look really clean.
