I don't know how common this issue is, but I'm already on my eighth mouse (maybe I missed something), and I've run out of models I can check. I need something with 12 programmable side buttons, but the available options are very limited. Brands like Logitech are no longer selling mice of this type.
This is the history I remember:
I don't have any problems with older Logitech or HyperX, but all the programmable buttons are missing there.
- Corsair Scimitar (first version) - the wheel broke, the plastic pin holding it cracked after about a year of use
- Corsair Scimitar (second, a bit improved version) - the wheel had that annoying "rubber-banding" issue when you scroll, and the screen gets back a bit randomly every 1-2 scrolls; problems with this mouse started after about 2 years.
- Corsair Scimitar - replacement - about 8 months to get the same issue
- Corsair Scimitar Pro - Corsair promised improvements but did nothing, I had the same problem after a year; I got my money back
- Razer Naga X - two problems, one with the scrolling and another with the sensor, I got a replacement
- Razer Naga X - a problem with scrolling again; I got my money back
- Corsair Scimitar Elite - because of a lack of other options with 12+ programmable buttons, and I wanted something wireless; the problem with scrolling started in about 5-6 months; so far I cleaned it, and it somehow works. I left it "just in case", and I bought another mouse ...
- SteelSeries Aerox 9 Wireless - I just made an RMA for the same scrolling issue after 4 months of use. There is no difference after cleaning with compressed air, and I can't open it, or I will lose the warranty (or at least have to buy new skates).
