- Oct 1, 2002
- Wellington, FL
My full build is at http://www.30moons.com/pc_chiapet.php
I have been happy with the performance and don't do a ton of gaming, but I am getting 'cannot find BIOS' and other errors/problems that require me to unplug the PC to get it to turn back on.
I have decided the i5-4690K and not sure on the mother board. Here is what I have currently and plan on reusing everything, but the old motherboard and CPU. I will by the proper bracket for my TRUE and probably use Coollaboratory Liquid Pro this time. I would like to overclock if possible.
Here is the relevant parts of my current build, I have a rather large case as well:
CPU: AMD Phenom II X4 955 BE C3 (3200MHz) Deneb CACAC AC 0946EPDW @3800MHz
CPU Voltage: 1.5
CPU Heatsink: Thermalright Ultra-120 Extreme
CPU Grease/Compound: Shin Etsu MicroSi G-751
CPU Fan: Gentle Typhoon D1225C12B5AP-15 120mm (Nidec D1225C12B5AP-53) (58.3 cfm / 28 dBA / 1850 rpm) x 2, Push/Pull
Motherboard: Gigabyte GA-990FXA-UD3
Memory: Kingston HyperX Blu KHX1600C9D3/4GX (4GBx2) and G Skill Ripjaws F3-12800CL9-4GBRL (4GBx2); 16GB Total
Memory Speed: 1600MHz 11-11-11-28-39 2T (should be able to hit 9-9-9-2x but it's not running at that speed)
Memory Voltage: 1.5
Case: Addtronics 7896A, fan cutouts modded to venturi shape. Cut out middle divider in rear for Thermalright 120 Ultra Extreme to vent properly.
Case Fans: 4 x NMB 80MM FBA08A12H1BX (39 CFM / 32 dBA / 2950 rpm) (3in/1out)
Power Supply: Corsair CMPSU-750HX 750W
Hard Drive 1: Seagate Barracuda ST31000524AS, 1TB, 32MB Cache at 7200RPM
Hard Drive 2: Hitachi Deskstar 7K1000 HDS721075KLA330, 750GB, 32MB Cache @ 7200RPM
Hard Drive 3: Western Digital WD Elements 2 TB USB 2.0
DVD±RW Manufacturer & Model: Pioneer DVR-216D with DVR-216L BIOS, 1.09 MCSE speedpatched firmware, 16x Max
Video Card: XFX Double D HD-687A-ZDFC Radeon HD 6870 1GB @ 900/1050MHz
Monitor: NEC LCD2490WUXi H-IPS LCD @ 1920x1200, calibrated via Eye-One Display LT/SpectraViewII
Wireless NIC: Intel Dual Band Wireless-AC 7260(7260HMWDTX1.R)
Operating System: Windows 10 64bit
I am open to used gear/eBay. I am also open to considering the AMD FX-8350 and a nice motherboard...I was seeing unless I am running multi-GPU's the performance is about the same. Money is a bit tight now as a single wage earner, with a family of 6 (one infant right now).
Thanks
Å
CPU Voltage: 1.5
Memory Voltage: 1.5
Thanks
Å
