ozzy0627 said:
Thanks Mpegger,
When you said software mpeg2 captures at high bit rate and I will have to convert to low bit rate.
Does that also go for any hardware mpeg2 encoder? The hauppauge pvr 250 has hardware mpeg2 encoder.
The problem with both software and hardware real-time encoders, is that thier very prone to having
alot of macroblocks in the video. FYI, macroblocks are the video artifacts that look like small squares of color. A poorly encoded mpeg video will have alot of macroblocks. Very low bitrates also cause macroblocks.
If you try to capture video at the bitrate for used for VCD (1500) in real-time, the video will come out with about 2x as many macroblocks as compared to one that was captured to a near lossless avi format, then recompressed with a software mpeg compresser. In order to reduce the macroblock problem, you would have to capture at higher bitrates, which you would then still have to convert to the smaller VCD bitrate.
So the best method (imo) is to just capture straight to AVI, clean up the video and make it easier for the mpeg format to compress, and then just convert it to mpeg. If I had my web server up, I'd show you some examples of what I mean, but its down for the count (registry somehow got all screwed up and wont boot into Windoze anymore
One other problem. Hardware encoders almost always have the codec built into the card, as well as limited capture resolutions and bitrates and the capture program that comes with is, is sometimes the only program you can use with it. So the codec cant be upgraded, and not all bitrates can be used for all capture sizes. Whatever quality you can get from it (good or bad), that all you'll be able to get from it.
With a software encoder, so long as you use a compatible program (WDM or VXD based), you can pretty much use any codec, bitrate, and resolution (limited by the capture chip) you want.
One more item I'd like to add. Hardware encoding is good and simple if you just want to capture vid and burn right away. Software is best, if you have the space, time, and want for the best capture you could possible get. Although you can clean up video made by hardware encoders, there are alot more utilities for the avi format.
Choose wisely ozzy-son.
