- Dec 1, 2016
HI guys I need little help once again. This case isn't popular at all so I wasn't able to google this problem.
I want to install 2 additional fans on the top BUT there is no clear indication how to open it up, yes there are
brackets for them. Tried to push those thingies in case from picture not a budge plus they are made of sharp plastic.
One is similar to Intel's pin from cooler but much stronger with metal thing inside, while another one is simple plastic
by looks of it its easy to remove with the panel once another one is released.
Altogether there are 6 pairs of those some are hard to get since case itself is in the way to some of them, those that
are closer to the front panel. I need any advice should I push? Pull? Screw off? Any advice is welcome
