MSI 360 AIO clogged after about 8 months...
I bought This AIO over a year ago and didnt finish the build as I was waiting for a 3080 but ended up with a 3090 after waiting for months. Everything ran great to start. I ran a lazy auto OC because temps were so low I just didnt take the time to go further.
Last week a woke up to my PC waiting in the BIOS. Tried rebooting several times with failed boot. Dialed things back and got it to boot but it was running hot. RPMs on pump showed that it was running fine. Tried several paste re apps with no change.
Then I went to taking apart the AIO. Opened and drained from the block, about a cup and a half of chunky milky fluid. The block was chuck full of white goop blocking the flow path to the copper fins. blasted the ports with air and filled it back with water the best I could and and was still getting just as bad or worse temps then before. Took it apart again this time taking the pump out of the rad, drained yet more chunky milk. Tested the pump on a system fan fork from another system ran fine and strong. I tired blasting the rad with a garden hose jet and got quite a bit more white junk out. Topped it back off with water and ran it, temps went from idle 60s to 23c.
This is discouraging for me for my first introduction to liquid cooling if you can even call an AIO that. I feel like a flow meter would have diagnosed this issue way faster.
I have an Artic freeze II 360 AIO coming this weekend to replace this AIO. I dont know how long the current one will last running well water.
Is this a common experience with AIOs in general? Would I be much better off going with a custom all copper liquid cooling loop? Should I just go back to air for reliability?
MSI Z490, 16GB gskill 3600, intel 10700k, nvidia 3090 founders,
