- Feb 7, 2013
Hey
Specs should be in my signature, the 4Ghz OC is at a fixed voltage of 1.17V.
I unplugged everything (incl. the PSU cable) and plugged everything in again, part by part. Seems to be working again
Never had the BIOS speaker built in though (didn't figure out where, when I started building this PC).
I get 1 Long, followed by 2 short beeps on start up. I googled it, but found no defintive answer. Can anyone enlighten me? I found GPU has detected a problem and parity error.
Original Post:
Symptoms are: No USB devices are powered, no video signal, fans are running, phase LEDs of GPU are on, no light on the MoBos I/O switch, nor does the lights at the LAN port work.
What I did
- rebooted couple of times, does only shutdown when IO switch is hold, reboots immediately, currently the PSUs I/O switch is set to off What I'll try right now:
- CMOS reset via jumper
Any input that helps me figuring this one out would be greatly appreciated
Original Post:
What I did
