Not at all. Any source that says that overclocking your card is automatically going to reduce the warranty to x number of days or years has no idea what they are talking about]
I don't think the article mentioned anything about warranty. They simply stated the lifespan of the GPU is shortened. If my 1080 ti dies within my 5 year warranty, you better believe I will be making sure I get a warranty replacement. I'm using the bundled software that came with my card, making no adjustments outside of the Zotac pre-defined limits set by them.
I can understand a company denying warranty based off a card whose bios has been flashed to another card, or in the case of someone physically modifying the card, but if it fails within 5 years simply because the slider is at 100% then I'd expect them to honor the warranty.
I really can't see a card die after a year of usage just because the voltage slider is at 100%, but what they're claiming is that setting it to 100% means the card runs full out even when idle. I will have to verify, but I'm pretty sure that is not the case. With voltage at 100%, power limit at 120%, and temp at 90c (all sliders maxed), I'm pretty sure my card sits at .8v when idle.
And I'm sure the Nvidia limit of 1.093v is their max voltage to not have cards burning up within the first few years. With the sliders maxed, I'm not seeing anything near that, so again I can't see the sliders causing premature death.
