VAMET
- Aug 3, 2014
- Gdynia, Poland
Dear Friends
First of all I would like to say hello to everybody, it's my first post here!
I own notebook MSI GX60 3BE with AMD A10-5750M and Radeon HD 8970M. When I had Windows 7, I have used AMD PSCheck to force my CPU to don't work below 3.2GHz. Now I have got Windows 8.1, but as far as I know AMD PSCheck doesn't work with this OS.
Do you know any method/application to force CPU to work/lock at 3.2GHz under Windows 8.1?
Windows Power Scheme with High Performance profile method doesn't force CPU to work all the time 3.2GHz, it's more flexible, because it sometimes drops under 3.2GHz, which is visible as performance drop in games.
I have installed AMD OverDrive, but I don't know how and if it's possible to lock CPU to 3.2GHz like in AMD PSCheck under Windows 7.
EDIT
I will be glad for any support and information, if it's possible to achieve such option via AMD OverDrive?
Thank you in advance.
Sincerely
EDIT
Sincerely
