MSI K7D Master & Radeon 9700 pro [Problems]
Jen
I installed the newest catalyst drivers and directx 9 . Everything was working well yesterday then this morning my monitior would not come out of suspend state. Pressed reset button and got video signal .
In windows it was working as it should then monitior blinked , then went blank. Just black screen.
I disabled monitior shut down in powermanagement. And tried a few different settings in bios but this problem remains.
Is there anyone out there useing a Radeon with this motherboard who can help me set the correct settings for bios and windows to make this card work?
J
Jen
nealric said:
I dont, but stericusaddict has a k7d master on a 9800pro, you can try pming him.
cant find this person when i did a search for this user name , is the spelling correct or can you direct me to one of this persons post so I can send them a PM
Jen
emboss
Canberra, Down Under
I've got a 9800SE softmodded to Pro (soon to be FireGL :) ) on a K7D-L. I've got everything enabled that people say not to (fastwrites, etc) and it still seems to work fine :)
J
Jen
i will try out the settings you gave me for bios , will also try some different drivers
Jen
David
Forums Super Moderator
Do you have the same problem starting in Safe Mode? or just on normal startup?
J
Jen
never tried safe mode , i will try some settings tomorrow when it is cooler and hope it helps. will try different drivers this time around
Jen
spldart
Sugar Land, Tx.
I have a 9800 pro in my k7d as well. No problems with compatibility and it comes back on out of monitor shut down fine. Can't think what you problem would be :(
Mine has worked with the last two bioses.
EZ-Spidey
What power supply are you using? Did you experience the same problems with
other, weaker video cards?
I'm having very similar problems but with my Ti-4600 and my Iwill MPX2. I tried
an old weaker card and everything is rock stable again and I know the Ti-4600
isn't defective.
From asking and looking around there was a strong possibility those problems
were power supply related.
I'm currently using an Antec TP 430w psu but my new OCZ PS 520w should be
here in a few hours.
I'd gladly let you know what's up once I install it if you want.
J
Jen
isn't defective.
Powersupply i am useing is Pcpower & Cooling 510 watt, dont think it has anything to do with that part
Maybe the video card is bad ,
Jen
TUK101
Wash. State
It could just be an overheating video card. The psu that you have is probably one of the best psu's made, so that shouldnt be it. Have you tried a different video card?
J
Jen
the matrox g400 i have works fine in the system.
trying to fit watercooling in this midtower case today .
Jen
cmcquistion
IT Director Senior
Tennessee
I ran a 9800 Pro in my AMD dually for a few months, with no problems, at all.
I now have a new P4 rig with the 9800 Pro in it.
One piece of advice I can give you is to get the best Radeon drivers available, which you won't get from ATI;)
Go to www.omegacorner.com and get his modified drivers. They are the best drivers you can get for an ATI card. He modifies and distributes Nvidia drivers, too. They are simply awesome. He is one person that I have gladly sent a donation to, because his work is just so good.
*EDITED the word 'makes' to 'modifies and distributes'
EZ-Spidey
I'm a 100% with cmcquistion on the Omega drivers.
I softmodded my Ti-4600 into a Quadro to use Maya PLE. It ran OK but
then I tried the Omega drivers and the difference was night and day.
J
Jen
couldnt make the card work correctly . probably the video card was bad.
still without my computer as the one waterblock i have has a cracked poly top. replaceing that one with a stainless steel top now
Jen
Dc5e
MA
the card still works in everything but windows? If so, then i wouldn't give up that easily. Obviously the card can display 2d, so therefore something in windows is messing it up. Have you tried safemode? I would double check the drivers.
