I just got the above yesterday, and the combo seems to work fine together. Now, I would like to try overclocking, as I bought a SVC copperheatsink with the new ystech 40cfm fan. at stock settings idle the computer processor is running about 95 degrees fahrenheit. The problem is, i cannot change the bus speed to 133mhz to run at 1ghz. I used the jumper on the motherboard and set it to 133mhz operation, but when I do that the computer wont even post, i have to revert back to 100mhz setting for it to even start. I do not want to join the L1 bridges if I dont have to. I just want to overclock using the FSB speed, rather than changing the multiplier. Is this possible?
