Ok guys and gals. I'm kinda torn on my decision. Last night I had what I think was an overheating issue. PC shut down and after a few moments it was able to be powered back up. Then about an hour or two later it did it again. But this time it would not power back up. I took pc apart cleaned it out really good. It was a mess. Guess I should of cleaned it out alot sooner. Anyway. I let it sit all night and it still would not power up this morning. I tested the power supply by jumping the green and black wires to see if the power supply worked. Luckily it did power up. So at least that is working. Hooked power supply back into the motherboard and still no go. Power button on case and the power button on the motherboard does nothing. Disconnect power supply from motherboard but leave all the peripherals hooked up to the power supply. All peripherals and anything else hooked up to it still power up and work (hard drives, fans, DVD ROM etc..). Hook power supply back up to motherboard and nothing. So while having everything hooked up I jumper the green and black wires on the power supply to motherboard connector. Everything powers up and works as it should. But if I remove that jumper. Nothing happens. Is it my power supply or is it the motherboard?
Thanks in advance.
System Specs....
MSI K9A2-Platunum
AMD Phenom II X4 955 Black Edition Deneb Quad-Core 3.2 GHz Socket AM3 125W
GeIL Black Dragon 8GB (4 x 2GB) 240-Pin DDR2
ENERMAX Liberty ELT620AWT 620W
Thanks in advance.
System Specs....
MSI K9A2-Platunum
