MSI KT4, POST your OC
deadzone
Panama
My OC is very poor so i just want to know what every one else has in this board to see where can i improve.
XP 1800+ @ 1730Mhz
512MB DDR 2100 KIngston CL2.5 @ 138FSB
(Memory in Auto Setup )
80GB WD 8MB Cache
MSI KT4 Ultra
G4 Ti200 210/470
Antec Case with 400Watts PSU
Water Cooling ( Sysfx.net Pump, Block, ExtremeIce Rad )
4 80mm Case Fan coolers ( 2 In, 2 Out )
2 120mm YS Fans ( 1 in Rad, 1 in Side ; bouth in )
I have a Kt 4 Ultra SR with an athlon xp 1600+ agoia Y. I am running the fsb up at 170 mhz right now with 1.85vcore. I have not unlocked yet and this is as high as i can safely go on air cooling (volcano 9, ducted).
this yeilds 1806 mhz as my oc. sandra reads 1.81 ghz. any higher than 170 gives me bsod's though. my crucial cas 2.5 pc 2700 cannot keep up to that, sadly.
I should note that this board has an automatic 166 fsb setting. if you set it to 166 in bios, it will enable the 1/5 divider. I would be interested to see if it has a 1/6 as well, but im not nearly brave enough ;)
Running at 10.5x171fsb @ 1.85 vcore...AMD 1600 AGOIA Y 13
Above it I start getting weird stuffs :)
Aggressive timings on Corsair XMS ram...
--fibo
MSI KT4VL (bios 1.1)
AXP 1600 (unlocked) AGOIA at 10.5x171 (1.85 vcore)
ATI Radeon 8500 64mb retail (283/275 - 6166 driver)
2x256 Corsair XMS PC2700 CL2 - 2-2-6-2 BI 4 - Ultra @ 2.6v
AX-7 with SmartFan II @ 75cfm
Windows XP Pro w/ SP1
2x60GB 5400rpm (NO raid)
Anix Platinum XP Case modded
The VIA KT-400 nas NO 1/6 - sad but true...
--fibo
I didnt think it did. but it would have been nice. 1/5 is fine though as 200 mhz only runs pci at 40 mhz. that isnt TOO bad. but it still too high for my liking.
kt4v OCed
kt4v + unlocked xp2000
1 piece samsung 512m pc2700
WD 60G
raidmax 400w psu
I'm still playing but so far:
10*183fsb 99% stable
11*174fsb most aggresive memory settings 100% stable
Anything over 186fsb causes data coruption on HD. I just can't get to 200Mhz which should equal pci speed of 40Mhz, even though the same hardware did pci/42 in a kr7a mobo with no data coruption. Not sure weather it is the memory or HD holding me back?
Re: kt4v OCed
WD 60G
raidmax 400w psu
Nice what's your vcore and memory voltages to achieve this?
--fibo
190x9.5, 1.775vcore, still tweaking memory will have benchies soon, but first i have to install a few programs after that data corruption (FSB200 is imposible with my HDD, hope i can hit it with the new sata HDD's) this is the highest i will go (38Mhz on the pci, but ive got more room on the vcore for a better multi)
he he. i think i saw 173 mhz somwhere in here at ... *blinks* 1.755... either that had weeks of burn in or it crashes ever other minute. heh. I think im going to burn in mine. I can see a glimmer of 2000 mhz hitting this cpu, but a burn in will be in order. i think ill lower it to 1400 again and run it at 1.85 for a few weeks to see if it can burn in . then MAYBE< i can hit 2 ghz without a huge volt mod.
unfortunatly, the most aggressive timings for ram i can get is 2.5,2,5,3 4way, 1T, 8qw and ultra speeds in the bios. if i run ras to cas at its most agressive, 2, it dies. lowering it to be equal or larger than the cas delay was nessisary to get stable operation. but I will be getting some cas 2 geil ram soonish with luck, so i will be able to test a few things out here.
but wish me luck on hitting 2000 mhz.
okay, VERY stable now @ 1720 with a XP1600 "y" 0213
180 fsb
stock voltage
if anyone knows of a better setting than this with stock voltage, ill try it out. (reason i am asking is that my cooling isnt up to par )
volcano9
36 idle
43?load
it getsREAL bad as soon as i up the vcore (39idle 48load) and thats just @ what i had before
erm. i have a volcano 9 running 51º load at 1800 mhz. its fine.
