MSI mobo mghtz analog display?
mrjones
Atlanta, GA.
First time poster - Love these forums very insiteful.
Question1:
Can the mghtz of the CPU be displayed by an external meter? For example does DOC5 display the mghtz the CPU is running at? If so, does it rely on a SW prog. to do so? How are the leads connected to the mobo? Is there a way to send the mghtz to an external meter, without SW/DOC5 support? Can it be sent to an analog meter?
Question2:
Same as above however replace with CPU usage. Can the CPU in use % be sent to an external anolog meter or display device?
Why would you do such a foolish thing?:
Am thinking about a cool retro mod that would use an external analog meter (you know the vU meters that tick up/down) to display the mghtz or CPU usage. Temp is pretty easy, however CPU % in use seems a bit more difficult. Suggestions?
Peace,
Hannibal
mrjones
mrjones
Atlanta, GA.
Thanks. This is a great resource...
re: Tach. Yeah I saw that. Not quite what I'm after, but interesting none-the-less. Did you happen to notice the "patent pending" line?
I'm pretty sure the tachometer has been done before.
Peace,
Hannibal
