- May 8, 2002
I've got a GeForce3 Ti200. When I originally received it, the drivers that I installed also added two MSI specific tabs to my "Display Properties" control panel (one "MSI Information" and the other "MSI Clock"). They worked beautifully for overclocking my card, even had a function to test it's highest possible overclock.
Fastforward a bit, I had to replace my motherboard. I did a repair install of WinXP (since XP really doesn't like it when you replace the mobo) and it saved all of my settings and files, however now those tabs don't work. I get a weird RunDLL error when I click on them. I get the feeling that they are missing some files, but I can't figure out which ones.
I tried their 3D! Turbo Experience software, but it barfs with the same error.
Does anybody know where I can get this util to reinstall it or find some way of removing those tabs?
Thanks in advance!
Jason
Thanks in advance!
Jason
