- Mar 11, 2001
I currently have a factory unlocked Tbird 1200, and a MSI Turbo motherboard (rev. 3 printed on the board). I cannot get the 133bus working correctly at all with this combo. I have to go into the bios, set my multiplier to 9 @100mhz, post, than manualy power down the system, remove the 133mhz bus jumper, turn computer back on, post at 9 @133. Everything works fine BUT if I power down the system for too long after it posts at 9 @133, 75% of the time I have to redo all these steps because the system hangs at initializing cpu. I've read about these cold boot up problems and it seems I'm experiencing it. Can this problem be remedied from a bios update or is this a hardware issue? Any advice or tips would be helpful. I also dont wish to physically alter my cpu either. =/
Btw, I can run my cpu rock solid at any 100mhz bus speed up to multiplier 12.5
